Mallow Carrier Board
Getting Started
This section contains initial information needed to set-up the Mallow Carrier Board for the first time.
Recommendation for the first-time order
Getting started
The Verdin SoMs come with Toradex Easy Installer pre-installed. Once you power-on the board, it will display a list of available images to be installed. Check out how to get started with the Toradex Easy Installer:
For quickstart step-by-step instructions about how to start using Torizon, please have a look at our step-by-step Getting-Started Guide:
The following Linux-based offerings are currently supported:
The debug UART signal levels on the Mallow carrier board are 1.8V, for more details please consult the datasheet. If you want to use USB-UART converters you should make sure that the chosen solution is compatible. It is recommend to use the FTDI TTL-232RG-VREG1V8-WE.
Additional information
For information on how to re-flash an operating system or image on the computer on module please check the Toradex Easy Installer article:
We have quick video tutorials:
For developing software on the platform, please browse through the list of knowledge-base articles provided in the link below:
Having trouble?
Please contact our technical support. Various option of technical support are mentioned below:
Hardware Features
Check the hardware features on the product page in toradex.com:
Block Diagram
Mallow Carrier Board V1.1A Block Diagram
Datasheets
Mallow V1.1 datasheetDesign Resources
Mallow Carrier Board V1.1 Design Data
- Mallow carrier board Altium project
- Mallow carrier board PDF Schematics
- Mallow carrier board Assembly Drawing
- Mallow carrier board Bill of Materials (BOM)
Verdin Specifications
Mallow Carrier Board V1.1A Mechanical Models
A basic 3D model for the Mallow carrier board can be downloaded here:
Design and Layout Guide
Altium Designer
Compatible Products
- Verdin AM62
- Verdin iMX8M Mini
- Verdin iMX8M Plus
- Verdin Industrial Heatsink
- Capacitive Touch Display 10.1" LVDS (with a compatible SoM)
- Capacitive Touch Display 10.1" DSI
Revision History
Product Number (PID8) Format
Field | Description |
PPPP | 4-digits number, indicating the Product Configuration (PID4) that describes the key properties of the product (e.g. Product Group, RAM capacity, etc.) |
VV | 2-digits number, indicating the Major and Minor Version (in that order) |
AA | 2-digits number, indicating the Assembly Variant |
Example
0029: Apalis iMX6D 512MB11: Major Version 1, Minor Version 1, Version V1.1 in short
00: Assembly Variant A
PN: 0161
Product # | Product Description | Changes from Previous Version | Release Date | Related Documents |
01611000 | Mallow V1.0A | Preliminary Version | - | Preliminary Version - No PCN document |
01611100 | Mallow V1.1A | Initial Public Release | October 2023 | Initial Release - No PCN document |
Errata/Known Issues
None
