How to use Matrix Keypad
A matrix keyboard can be used as an input device in different applications.
Use cases:
  • Keypad in handheld devices.
  • Access control systems, for keying in ID number and password, etc.
  • Low-end point of sale terminals which are not equipped with touch screen interface.
  • and many more..
This tutorial demonstrates how to interface 4x4 matrix keypad with Toradex module & Iris Carrier Board V1.1 A.
Schematic diagram
Image of keypad used:
Schematic diagram:
Demo application in C
  • Download demo code from the Download Section.
  • Build and deploy the application.
  • Navigate to My Device > Program Files > matrixkeypad_demo and run the application matrixkeypad_demo.exe.
Demo application in CSharp
  • Demo application can be downloaded from the Download Section.
  • Build and deploy the application on your WinCE device.
  • Go to My Device > Program Files > vcsharp_matrixKeypad_demo and run the application vcsharp_matrixKeypad_demo.exe.
Following GUI will open. Press Start Scanning button to start the scanning.
A box on output window will glow with green color on pressing respective button on matrix keypad as shown below.
Download Section
Note: For better results, keybd_event function can be used to keep the current status of the keys and synthesizes a keystroke. It may be useful to implement debouncing and to generate actual key strokes, allowing the matrix keyboard to behave like a regular one. This will also support auto-repeat and other typical keyboard behaviours. For more information, check this MSDN article.
