Overlay Lib API
Library of support functions for Overlays.
Data Structures
struct  XLLP_OVERLAY_T
Macros
#define OVL_VER_MAJ   0
#define OVL_VER_MIN   2
#define OVL_VER_BUILD   1
#define FORMAT_RGB   0x0
#define FORMAT_PACKED_444   0x1
#define FORMAT_PLANAR_444   0x2
#define FORMAT_PLANAR_422   0x3
#define FORMAT_PLANAR_420   0x4
#define BPP_1   0x001
#define BPP_2   0x002
#define BPP_4   0x004
#define BPP_8   0x008
#define BPP_16   0x010
#define BPP_18   0x020
#define BPP_18_PACKED   0x040
#define BPP_19   0x080
#define BPP_19_PACKED   0x100
#define BPP_24   0x200
#define BPP_25   0x400
#define O_BPP_4   0x2
#define O_BPP_8   0x3
#define O_BPP_16   0x4
#define O_BPP_18   0x5
#define O_BPP_18_PACKED   0x6
#define O_BPP_19   0x7
#define O_BPP_19_PACKED   0x8
#define O_BPP_24   0x9
#define O_BPP_25   0xA
Typedefs
typedef struct XLLP_OVERLAY_TP_XLLP_OVERLAY_T
Functions
void OVLGetLibVersion (DWORD *pVerMaj, DWORD *pVerMin, DWORD *pBuild)
BOOL LCDInit (void)
void LCDDeInit (void)
void LCDDegrade (BOOL degrade, DWORD color)
BOOL Overlay_Setup (P_XLLP_OVERLAY_T pXllpOverlay)
BOOL Overlay_Enable (P_XLLP_OVERLAY_T pXllpOverlay)
void Overlay_Disable (P_XLLP_OVERLAY_T pOv)
void Overlay_GetBuffer (P_XLLP_OVERLAY_T pOv)
void Overlay_Flip (P_XLLP_OVERLAY_T pOv)
BOOL Overlay_PosSizeFormat (P_XLLP_OVERLAY_T pOv)
void SetTransparencyFactor (DWORD n)
BOOL Overlay2_Setup (P_XLLP_OVERLAY_T pXllpOverlay)
void Overlay2_Flip (P_XLLP_OVERLAY_T pOv)
void Overlay2_GetBuffer (P_XLLP_OVERLAY_T pOv)
void Overlay2_Disable (P_XLLP_OVERLAY_T pXllpOverlay)
void Overlay2_Enable (P_XLLP_OVERLAY_T pXllpOverlay)
#define BPP_1   0x001
#define BPP_2   0x002
#define BPP_4   0x004
#define BPP_8   0x008
#define O_BPP_4   0x2
#define O_BPP_8   0x3
Typedef Documentation
Function Documentation
void LCDDegrade(BOOL degrade,
  DWORD color
Degrades the dispay to 1 bit per pixel (to save bandwidth)
Parameters
[in]degradeTRUE: Degrade, FALSE: Normal display
[in]colorPalette color entry
void LCDDeInit(void  )
Release the library - call when finished with the library
Return values
TRUE= Success
BOOL LCDInit(void  )
Initialise the library - call before using other functions
Return values
TRUE= Success
void Overlay2_Disable(P_XLLP_OVERLAY_T pXllpOverlay)
Disable the overlay - deprecated
Parameters
[in]pXllpOverlayPointer to Overlay data structure
[out]pXllpOverlayPointer to Overlay data structure
Deprecated:
void Overlay2_Enable(P_XLLP_OVERLAY_T pXllpOverlay)
Enable the overlay - deprecated
Parameters
Deprecated:
void Overlay2_Flip(P_XLLP_OVERLAY_T pOv)
Flip the overlay - deprecated
Parameters
[in]pOvPointer to Overlay data structure
[out]pOvPointer to Overlay data structure
Deprecated:
void Overlay2_GetBuffer(P_XLLP_OVERLAY_T pOv)
Get the overlay buffer - deprecated
Parameters
Deprecated:
BOOL Overlay2_Setup(P_XLLP_OVERLAY_T pXllpOverlay)
Setup the overlay - deprecated
Parameters
Deprecated:
void Overlay_Disable(P_XLLP_OVERLAY_T pOv)
Disable the overlay
Parameters
BOOL Overlay_Enable(P_XLLP_OVERLAY_T pXllpOverlay)
Enable the overlay
Parameters
Return values
TRUE= Success
void Overlay_Flip(P_XLLP_OVERLAY_T pOv)
Flip the overlay buffer
Parameters
void Overlay_GetBuffer(P_XLLP_OVERLAY_T pOv)
Parameters
BOOL Overlay_PosSizeFormat(P_XLLP_OVERLAY_T pOv)
Update the overlay Position, Size and Format
Parameters
Return values
TRUE= Success
BOOL Overlay_Setup(P_XLLP_OVERLAY_T pXllpOverlay)
Setup the overlay
Parameters
Return values
TRUE= Success
void OVLGetLibVersion(DWORD * pVerMaj,
  DWORD * pVerMin,
  DWORD * pBuild
Get the library Version.
Parameters
[out]pVerMajMajor version number.
[out]pVerMinMinor version number.
[out]pBuildBuild number.
void SetTransparencyFactor(DWORD n)
Set the overlay transparency factor
Parameters
[in]nTransparency level, 0: very transparent, 7: fully opaque
