하이라이트
Equipped with NXP i.MX 6ULL SoCs, the Arm Cortex-A7 single core is clocked at 528 MHz, 800 MHz or 900 MHz depending on the configuration of the SoM.
The NXP i.MX 6ULL SoC is a power-efficient processor which, in addition to being a single-core, allows for a power dissipation of the Toradex SoM in the order of 0.4W to 1.2W, depending on the system load.
Simplify your design with pre-certified wireless options, counting from the module to the antennas, to increase the predictability of end-device certification processes while enabling significant cost savings. The latest 802.11ac standard and support for multi-antenna setups contribute to a great out-of-the-box end-user experience. These are paired with Bluetooth 5 support to offer state-of-the-art integration for Bluetooth devices.
Carrier boards designed for the Colibri iMX6ULL are not just compatible between the four Colibri iMX6ULL modules—in fact, they are compatible with the complete Colibri family, including the NXP i.MX 8X, i.MX 7, i.MX 6 and NVIDIA Tegra-based modules. This gives you unmatched flexibility and easy upgradability. To make carrier board design as easy as possible, we provide the Toradex Pinout Designer Tool.
Colibri iMX6ULL offers a low-cost and power-efficient platform to build a wide range of IoT and embedded devices. It is suitable for headless applications, or static GUIs and light multimedia as low resolution video.
운영 체제
Toradex offers free support and maintenance for Embedded Linux on the NXP i.MX 6ULL processor based Colibri iMX6ULL SoM. This allows system designers to focus on the application instead of focusing on the OS and low-level device drivers.
특징
CPU Name | NXP i.MX 6ULL |
CPU Type | 1x Arm Cortex-A7 |
CPU Clock | up to 900 MHz |
NEON | Yes |
L1 Instruction Cache | 32KB |
L1 Data Cache | 32KB |
L2 Cache | 128KB |
RAM | Up to 1GB DDR3L (16 Bit) |
Flash | Up to 4GB eMMC |
USB 2.0 | 1x Host / 1x OTG |
Ethernet | 10/100 Mbit with IEEE 1588 (+2nd RMII) |
Wi-Fi | Dual-band 802.11ac 2x2 MU-MIMO |
Bluetooth | Bluetooth 5 |
I2C | 3x |
SPI | 3x |
UART | 8x |
IrDA | 1x |
PWM | 8x |
GPIO | up to 94 |
Analog Input | 8x |
SDIO/SD/MMC | up to 2x |
CAN | 2x |
JTAG | 1x |
Display Controller | Single |
Digital Audio | 3x SAI |
Parallel RGB | 1366 x 768 x 18bpp |
Resistive Touch | 4-wire |
Camera Parallel Interface | 1x 8/10/16/24 Bit |
Size | 67.6 x 36.7 x 6.2 mm |
Temperature | -40° to +85° C(1) |
Power Dissipation | 0.4 - 1.2 W |
1 - The Wi-Fi/Bluetooth module featured on the SoM is rated for an operating temperature range of -30°C to +85°C. As this component is not deemed boot-critical, the SoM is still listed as an industrial temperature range product.
Colibri iMX6ULL 1GB
ITPN: 0062
A7
1GB RAM
4GB FLASH
-40° to +85° C
Colibri iMX6ULL 512MB
Wi-Fi / Bluetooth ITPN: 0040
A7
512MB RAM
512MB FLASH
-40° to +85° C
Wi-Fi / BluetoothPN: 0045
A7
512MB RAM
512MB FLASH
-0° to +70° C
ITPN: 0044
A7
512MB RAM
512MB FLASH
-40° to +85° C
최적의 SoM을 선택하는 데 도와주세요
안내해주세요Get Started
Colibri iMX6ULL Evaluation Kit
US$490.70
- One Cortex-A7 800 MHz processor
- NXP i.MX 6ULL applications processor
- Parallel RGB or VGA up to 1366 x 768 x 18bpp (via converter)
Colibri iMX6ULL Kit 2
US$311.70
- Arduino Uno and Raspberry Pi Compatible Pin Headers
캐리어 보드
SBC와 캐리어 보드에 대해 자세히 알아보기액세서리
- No special drivers required
- Atmel touch driver
- Cable length: 100mm
- Manufacturer: Unictron
- Manufacturer: Chang Hong
- Reference: DA-2458-02
- Cable length: 200mm
생태계
Toradex Easy Installer
Toradex Easy Installer allows you to install an OS in one click. It comes preinstalled from the factory, so all you need to do is turn on your on Colibri iMX6ULL and choose an OS!
Colibri iMX6ULL does not have a GPU. Nevertheless, choosing a GUI framework that supports optimized graphics on the CPU is a great choice for a modern UI with moderate level of animations. Toradex partners closely with leading GUI technology providers to simplify the development process and make sure that hardware resources are utilized effectively.
Qt Framework
Get started with QtTotalCross
Get started with TotalcrossIndustrial Automation
CODESYS PLC IEC 61131-3
The Colibri iMX6ULL is a good fit for industrial automation tasks. CODESYS allows you to develop easily customized PLCs powered by a proven, long-lived software solution.
Get started with CODESYS on Toradex SoMsMatrikon OPC UA
OPC UA is a standard technology widely used in industrial automation. The stack from Matrikon is a reliable, secure and platform-independent implementation that suits the Colibri iMX6ULL perfectly.
Watch our webinar with BE.services로드맵
Hardware Roadmap
- Q2'23
- Q3'23
- Q4'23
- Q1'24
- Q2'24
- In Development
- Sample Production
- Volume Production
Software Support Status
