하이라이트
The NXP i.MX 8M Mini SoC comes with up to four powerful 64-bit Armv8 Cortex-A53 cores, making it a cost effective choice for running Linux with a modern graphical user interface while providing sufficient power reserves for typical industrial and medical applications.
Verdin Product Family
The heterogeneous multicore architecture allows the offloading of critical hard real-time tasks to the Cortex-M4 processor for extremely low latency. Toradex provides tooling and FreeRTOS to simplify development. You can also use the asymmetric multicore architecture for a connected low power mode or to increase security.
The i.MX 8M Mini is manufactured using the low-power 14LPC FinFET Technology, making the SoC power-optimized. In addition, the Verdin form factor allows you to power off peripherals on the carrier board, and the auxiliary Cortex-M4 core can run while the main Cortex-A53 cores are powered off.
Released in 2020, the Verdin form factor is ideal for new and upcoming projects, as it features a range of modern interfaces that include Gigabit Ethernet, MIPI CSI-2 Camera, MIPI DSI Display, PCIe, Quad SPI and CAN. The 1.8 V I/O voltage level is ideal for future-proof power- and cost-optimized designs.
Simplify your design with pre-certified wireless options, counting from the module to the antennas, to increase the predictability of end-device certification processes while enabling significant cost savings. The latest 802.11ac standard and support for multiantenna setups contribute to a great out-of-the-box end-user experience. These are paired with Bluetooth 5 support to offer state-of-the-art integration for Bluetooth devices.
With up to four powerful Arm 64-bit Cortex-A53 cores, the Verdin iMX8M Mini is a cost-effective choice for running Linux with a modern graphical user interface while providing sufficient power reserves for serving typical industrial and medical applications.
운영 체제
Toradex offers free support and maintenance for Embedded Linux and FreeRTOS on the NXP i.MX 8M Mini processor based Verdin iMX8M Mini SoM. This allows system designers to focus the application only, instead of focusing also on the OS and low-level device drivers. Other OS such as Android and QNX are supported by our partners.
Android is supported by our service partner Kynetics. An Evaluation will be provided free-of-charge as a binary installer directly on Toradex Easy Installer feeds.
QNX is a microkernel-based real-time operating system, primarily targeting embedded systems requiring high safety and security. An evaluation image is provided for Verdin iMX8M Mini directly from BlackBerry/QNX.
특징
CPU Name | NXP® i.MX 8M Mini |
Microcontroller | 1x Arm Cortex™-M4 |
CPU Clock | up to 1.8 GHz (A53) 400 MHz (M4) |
Floating Point Unit | VFPv4 |
NEON | Yes |
L1 Instruction Cache | 32KB (A53) 16KB (M4) |
L1 Data Cache | 32KB (A53) 16KB (M4) |
L2 Cache | 512KB |
Flash | Up to 16GB eMMC |
USB 2.0 | 1x Host / 1x OTG |
Ethernet | Gigabit with TSN |
Bluetooth | Bluetooth 5.3 |
PCIe | 1 (x1 Gen 2) |
I2C | 3x |
SPI | 3x |
QSPI | 2x |
UART | 4x |
PWM | 4x |
GPIO | 98x |
Analog Input | 4x |
SDIO/SD/MMC | 2x |
CAN | 1x |
JTAG | 1x |
Display Controller | Single |
Graphics Controller | 2D: Vivante GC320 3D: Vivante GCNanoUltra |
Video Decoder | Yes |
Video Encoder | Yes |
Display Serial Interface | 1x Quad Lane MIPI DSI (up to 1920x1080) |
LVDS | Via External Conversion From MIPI DSI |
Digital Audio | 5x SAI: I2S or AC97 |
S/PDIF In / Out | 1x / 1x |
2D Acceleration | Yes |
3D Acceleration | Yes |
Size | 69.6 x 35.00 x 6.0 mm |
Temperature | -40° to +85° C(1) |
Power Dissipation | Approx. 1.2W - 7.5W |
최소한 다량 구매
from US$44.90
Verdin iMX8M Mini
Quad 2GB Wi-Fi / Bluetooth ITPN: 0055
A53
A53
A53
A53
M4
3D GPU
VPU
2GB RAM
16GB FLASH
-40° to +85° C
Verdin iMX8M Mini
Quad 2GB ITPN: 0059
A53
A53
A53
A53
M4
3D GPU
VPU
2GB RAM
16GB FLASH
-40° to +85° C
Verdin iMX8M Mini
Quad 2GB Wi-Fi / Bluetooth IT (No CAN)PN: 0068
A53
A53
A53
A53
M4
3D GPU
VPU
2GB RAM
16GB FLASH
-40° to +85° C
Verdin iMX8M Mini
DualLite 1GB Wi-Fi / Bluetooth ITPN: 0060
A53
A53
M4
3D GPU
1GB RAM
8GB FLASH
-40° to +85° C
최적의 SoM을 선택하는 데 도와주세요
안내해주세요Get Started
Verdin iMX8M Mini Evaluation Kit
US$670.70
- Up to four Cortex-A53 1.8 GHz processors
- Cortex-M4 processor with speeds up to 400 MHz
- NXP i.MX 8M Mini applications processor
Verdin iMX8M Mini Evaluation Kit 2
US$369.70
캐리어 보드
SBC와 캐리어 보드에 대해 자세히 알아보기액세서리
- Cable length: 100mm
- Manufacturer: Unictron
- Manufacturer: Chang Hong
- Reference: DA-2458-02
- Cable length: 200mm
생태계
Toradex Easy Installer allows you to install an OS in one click. It comes preinstalled from the factory, so all you need to do is turn on your Verdin iMX8M Mini and choose an OS!
The Verdin iMX8M Mini provides high-performance graphics. Toradex partners closely with leading GUI technology providers to simplify the development process and make sure that hardware resources are utilized effectively.
Qt Framework
Get started with Crank StoryboardEdge Computing
AWS IoT Greengrass
AWS provides a wide range of services to help you build scalable industrial IoT solutions. AWS IoT Greengrass is a key tool that runs directly on the Toradex SoM. Currently AWS, NXP and Toradex collaborate closely.
Get started with AWS SageMaker NeoIndustrial Automation
CODESYS PLC IEC 61131-3
The Verdin iMX8M Mini is a robust SoM, and its high performance is ideal for demanding industrial automation scenarios. CODESYS allows you to develop easily customized PLCs powered by a proven, long-lived software solution.
OPC UA is a standard technology widely used in industrial automation. The stack from Matrikon is a reliable, secure and platform-independent implementation that suits the Verdin iMX8M Mini perfectly. You can integrate it yourself, or leverage the expertise of our partner, BE.services, to outsource integration.
Watch our webinar with BE.services로드맵
Hardware Roadmap
- 2024
- 2025
- 2026
- 2027
- 2028
- 2029
- 2030
- In Development
- Early access product
- Sample Production
- Volume Product Candidate
- Volume Production
Software Support Status
