Repository Sharing
This article explains how to share devices, fleets, security credentials, and package updates between different users of Torizon Cloud.
Account & Repositories
The resources available on your Torizon Cloud account - fleets, devices, API clients, security credentials and updates - are organized in a repository that can be shared between different users. Your repository is created when you create your account in Torizon Cloud. You can invite other users of Torizon Cloud to your repository with different Guest Profiles. This also allows you to access other user's repositories.
Make sure to follow the best practices for device provisioning so you can fully leverage the Repository Sharing feature.
Check in the picture below how to access the Repository Sharing feature under your Torizon Cloud Account section (1), how to invite users (2) with different Guest Profiles (3), and how to access repositories shared with you (4).
Guest Profiles
When inviting users to access your repository, you should set the Guest Profile. Each Guest Profile gives a different access level to the features. Check the table below:
Read Access | Update Access | Device Manage | Full Access | Repository Owner | |
View Fleets & Devices | ✓ | ✓ | ✓ | ✓ | ✓ |
Create, read, update and delete Fleets | - | ✓ | ✓ | ✓ | ✓ |
Publish Updates | - | ✓ | ✓ | ✓ | ✓ |
Create Devices (Provisioning) | - | - | ✓ | ✓ | ✓ |
Create, read and delete Packages | - | - | - | ✓ | ✓ |
Download credentials.zip | - | - | - | ✓ | ✓ |
View API Clients | - | - | - | - | ✓ |
Create API Clients | - | - | - | - | ✓ |
Invite users to the repository | - | - | - | - | ✓ |
