Torizon OS Upgrade Notes
In this article, you will learn about the technical details of Torizon OS releases which impact customers when upgrading.
Torizon OS releases are maintained according to our Embedded Linux Support Strategy.
Release Details and Upgrade Notes
In this section, you find notes on the impact of updating to a newer Torizon OS release.
Torizon OS 6.6.1
Torizon OS 6.6.1 is a quarterly release from the Torizon OS 6 series.
- All users of the Torizon OS 6 series should update to this release until it is superseded. All previous Torizon OS 6.X (formerly named TorizonCore) releases will not be patched - maintenance releases are based on the latest quarterly.
- If your product has a cellular modem, consider tweaking the default ModemManager configuration so the number of connection retries is set to infinite, as documented on Modem Support - Set Cellular Connection Retries.
- Online and offline updates can now be enabled both at the same time. Learn how to do it on How to Use Secure Offline Updates with Torizon OS - Configure Device for Offline Updates.
- A new sample for Hardware-accelerated video playback and encoding on NXP i.MX 8 SoMs has been published. Documentation is available on How to use Gstreamer on Torizon OS and the sample is available in the GitHub repository toradex/torizon-samples.
Read the Torizon OS 6.6.1 release news for a complete list of updates and highlights for this release.
Torizon OS 6.5.0
Torizon OS 6.5.0 is a quarterly release from the Torizon OS 6 series.
- If your product has low or unstable connection to the internet and you perform remote updates, consider tweaking the default configuration to make your updates more robust, as documented on Configuring Options for Low-Bandwidth Connections.
- Device monitoring data buffering is now available. The default values are a reference implementation. If you use device monitoring and your device has intermittent connection to the internet, it is recommended that you adjust the parameters to your use case constraints, as documented on Data Buffering.
- eMMC lifespan has been added to the default device monitoring metrics. If you use device monitoring, review whether it makes sense to follow the default or remove this metric.
- .NET 8 containers for Torizon are released, following the .NET 8 release announcement:
- You are encouraged to migrate your .NET 6 project to .NET 8 before it reaches End-Of-Life (EOL) by the end of 2024, according to the Microsoft's .NET and .NET Core Support Policy.
- Consult the Microsoft documentation to learn about What's new in .NET 8 and Breaking changes in .NET 8.
- We recommend you develop your .NET 8 project with our Visual Studio Code IDE Extension for Torizon. .NET 8 templates are available for various use cases: C# console, ASP.NET Blazor, Avalonia, Uno Platform, and Slint.
- A Qt 6 template is available for the VS Code IDE Extension for Torizon, providing an improved user experience that is built on top of the Debian Containers provided in the previous quarterly 6.4.0 release.
Read the Torizon OS 6.5.0 release news for a complete list of updates and highlights for this release.
Torizon OS 6.4.0
Torizon OS 6.4.0 is a quarterly release from the Torizon OS 6 series.
- Qt 6 Debian Containers for Torizon are available and support hardware acceleration. Updates to the related documentation and the VSCode Torizon template should happen after this release. Before this update, projects based on this template will rely on the software-rendered implementation.
- If your use case relies on hardware acceleration and you can't wait for the template and docs update, you may want to try the new containers by replacing your project Dockerfile's
FROM
statement to use one of the following:torizon/qt6-wayland
for SoMs based on NXP i.MX 6/6ULL/7 or;torizon/qt6-wayland-vivante
for SoMs based on NXP i.MX 8/8X/8M Mini/8M Plus. - For testing purposes, you can run examples with the
torizon/qt6-wayland-examples-vivante
container. Thetorizon/qt6-wayland-examples
container is not available because the Qt 6 examples package is not available in the Debian feed. - Python bindings are not yet easy-to-use. As a hint, you may use PyQt6 which already has Debian packages available, or PySide6 which doesn't have the packages available but on the other hand has a license that may better suit your product. See a comparison on PyQt6 vs PySide6.
- The Debian Containers for Torizon were rebuilt against the Debian 12.1 point release. You are encouraged to update the Debian Containers used in your project to our latest containers release.
Read the Torizon OS 6.4.0 release news for a complete list of updates and highlights for this release.
TorizonCore 6.3.0
TorizonCore 6.3.0 is a quarterly release from the TorizonCore 6 series.
- All users of the TorizonCore 6 series should update to this release until it is superseded. All previous TorizonCore 6.X releases will not be patched - maintenance releases are based on the latest quarterly.
- An alternative method for configuring Wi-Fi Access Point (AP) and hotspot has been introduced due to a bug that prevents NetworkManager instructions to work. Learn how to apply it on Networking with TorizonCore - Wi-Fi access point mode - Method 2: Hostapd.
- Debian Containers for Torizon based on Debian Bookworm are available with the major tag
3
. Even though the previous Debian Bullseye containers with the major tag2
are expected to work, only the newer ones are supported in TorizonCore 6. Read the article TorizonCore Containers Tags and Versioning for more details on how the compatibility between containers and TorizonCore is defined. Since this is the first release of the Debian Bookworm containers, all of the points below are considered breaking changes between TorizonCore 5 and 6:- A breaking change has been introduced on how to start the Weston and Browser containers. The up-to-date commands are available on Debian Containers for Torizon - Debian With Weston Wayland Compositor, Web Browser / Kiosk Mode with TorizonCore - Running Chromium and Web Browser / Kiosk Mode with TorizonCore - Running Cog.
- The GitHub repository torizon-containers supersedes and unifies all the content from debian-cross-toolchains, debian-docker-images, debian-dotnet-development-images, and rt-validation. With a regular workflow, you will build your own docker images on top of our pre-built images provided on Docker Hub, and thus you won't be affected by this change. Nevertheless, if you have chosen to rebuild our images from source, you must use the new repository from now on.
- GLX support on Xwayland and gst-plugins-base1.0 for i.MX 8/8X/8M Mini/8M Plus has been removed from our Debian packages, as it was done by NXP in their forks of these packages. Glamor support for hardware-accelerated 2D rendering is available and you must plan to switch to using it - though due to the bug xwayland: glamor support broken on iMX8 it is currently falling back to software rendering.
Read the TorizonCore 6.3.0 release news for a complete list of updates and highlights for this release.
TorizonCore 6.2.0
TorizonCore 6.2.0 is a quarterly release from the TorizonCore 6 series.
- All users of the TorizonCore 5 series can upgrade to TorizonCore 6. Upgrade instructions are available on Upgrading from TorizonCore 5.x to TorizonCore 6.x.
- The
torizon/debian-shell
container has been deprecated in TorizonCore 6. The impact should be minimal since thetorizon/debian
container is an easy-to-migrate replacement, as can be seen in the List of Container Images for Torizon. To migrate, check the packages installed on torizon/debian-shell and install the ones you rely on to your container based ontorizon/debian
Read the TorizonCore 6.2.0 release news for a complete list of updates and highlights for this release.
TorizonCore 6.1.0
TorizonCore 6.1.0 is the first quarterly release from the TorizonCore 6 series.
- All users of the TorizonCore 6 series should update to this release until it is superseded. All previous monthly pre-releases will not be patched - maintenance releases are based on the latest quarterly.
- All users of the TorizonCore 5 series should upgrade to TorizonCore 6. There are available instructions for Upgrading from TorizonCore 5.x to TorizonCore 6.x.
- Colibri SoMs: the spidev overlay has been disabled by default, due to a conflict with the SPI-to-CAN transceiver on the Colibri Evaluation Board. If you use spidev, you must enable the corresponding overlay. Read the issue TOR-2746 in our issue tracker to learn more.
- The ecosystem around TorizonCore 6 has limitations. If you have experience with TorizonCore 5, read the release news below to learn what are the limitations.
- You should not rely on the
debian-shell
container in TorizonCore 6, as we have deprecated it. The impact should be minimal since thedebian
container is an easy-to-migrate replacement, as you can check in our List of Container Images for Torizon. To migrate, check the packages installed on debian-shell and install the ones you rely on into your container based ondebian
Read the TorizonCore 6.1.0 news and the TorizonCore 6.0.0-devel-202210 news for a complete list of updates and highlights for this release, as well as why 6.0.0 was not a quarterly release.
TorizonCore 5.7.2
TorizonCore 5.7.2 is a maintenance release of the 5 series which supersedes 5.7.0.
- All users of previous versions of the 5 series should update to this version until it is superseded.
- This release enables bootloader updates and allows users to upgrade from TorizonCore 5 to 6, by using it as a bridge. Learn more on Bootloader updates article.
Read the TorizonCore 5.7.2 release news for a complete list of updates and highlights.
TorizonCore 5.7.0
TorizonCore 5.7.0 is the Latest Quarterly Release of the 5 series.
- According to our support strategy, all previous quarterly releases will not be patched - maintenance releases are based on the latest quarterly.
- The TorizonCore team only tests updating from the immediately previous TorizonCore release. In this case, from 5.6.0 to 5.7.0. If you plan to update from any other previous release, you must validate it, since it is not a supported scenario.
Read the TorizonCore 5.7.0 news for a complete list of updates and highlights.
TorizonCore 5.6.0 and older
Upgrade notes were released starting from TorizonCore 5.7.0 onward. For older releases, please read the corresponding TorizonCore news on toradex.com:
